MrUnlimited
Guys:
I have a problem: when I prime the bulb it fills halfway and then it pressure the fuel though the airtube back to the tank. Engine will not get any fuel and won't start. I tried it with the stock Carb and the WT813. Both have the same problem. Both carb needles are set to 1,5 turns on both the carbs. Is the carb the problem or there something wrong with engine? All gaskets are almost new so I don't think it is an airleak. Someb ody has the answer?
