Sounds like my problem, got to give that a try.Phill said:No probs here once I found out you only move the screws one hair at a time.Before that I was too heavy handed.
What's wrong at your end?
Sounds about right, thats why I pulled it off. Let me know if you find one easier to tune.Silent_chaos said:Im having a lot of trouble starting the engine. Usually 20 pulls or so. Engine floods. Pull the plug. Engine fuel drain. Reinstall plug. Another 5 pulls to start.I guess its the carb. I dunno.
Gonna try the 998 in 3 or 4 weeks. I'll surely let you knowclaude bigelow said:Sounds about right, thats why I pulled it off. Let me know if you find one easier to tune.
Does that have a choke on it?Silent_chaos said:Gonna try the 998 in 3 or 4 weeks. I'll surely let you know
No choke. its the same as the 990, but it has a pump inside.claude bigelow said:Does that have a choke on it?
Mine is 2 slow pulls after priming the bulb and it starts on the next hard pull.Silent_chaos said:Im having a lot of trouble starting the engine. Usually 20 pulls or so. Engine floods. Pull the plug. Engine fuel drain. Reinstall plug. Another 5 pulls to start.I guess its the carb. I dunno.
It's an exciter pumpSilent_chaos said:No choke. its the same as the 990, but it has a pump inside.And according to my calculations, i guess with a pump(998) you can squeeze out more power. Same concept of your casual every day car. More pressure from Fuel pump means more bhp.
I know this from my brother's turbo car, he has a 160bar fuel pump and he wants to put another one.
