We gave up running the beadlock type tire system a few seasons back and are now running the 180mm grp rims and tires that MCD use on their race buggies, The GRP soft and med compounds are true race tires and have massive hookup on 2wd 5Bs , The hex hubs need to have .100 taken off wheel side face so there is more thread out of rim face for wheel nuts, That's done. Now the large OD of these bad boys will make lower powered motors fall on their face even with the 16-58 gearing setup, Now the fix. HPI made 2 different tooth count upper gear for the inside of gear case, A 19 tooth for truck and a 20 tooth for buggy. You want to change to the 19 tooth for more low end and take load off motor and make the rollout right, DDM sells the 19 tooth in their Black Magic line of HD gears for the buggy tranny . You will never go back after running this setup
