was the difference of da 2 which is better
Same Thing with Different Gears,Wheels, Body mounts and Body :) The MT Is a Beast I has lower gears to turn bigger wheels!! And u can change to TT wheels and with lower gearing have crazy low end :)
Buy MT U will be happy :)
The XT, XB & XSC are the same chassis, motor and suspension. The only differences made between the three are to make them look like different rides. The XT has bigger wheels so the ground clearence is higher. This line of trucks has more plastic and less metal. This is good for speed but is not as strong.
The MT and TT are the same chassis, motor and suspension. This line has more metal and is the most durable of the Redcat lineup. The MT is a heavy truck and is a beast. It is great for bashing. The tires on the MT are huge. Currently the MT has the most hop ups available if your into that.
All the Redcat large scale trucks come with the same 30.5cc engine. So the smaller are a little faster due to less weight.
IMO if you want the monster truck look get the MT. If you want a buggy get the XB. If you like the desert truck look still get the mt and modify it. I have a thread called trophy truck under projects. A lot of guys get the MT and run bodies and wheels from other brand trucks.
You should call one of the sponsors to the left when your ready to buy. They would have all info to help you make your decision.
That's a great idea!
