Water
Marc101885
How do the electronics hold up on these trucks when they get wet? I'm not talking about turning the truck into a submarine, but running through puddles, wet grass, mud and such. Yeah its a rainy day and i want to go bashing
The box is set up where you should be ok. I would check after one tank and look in the box and see if water getting in. Maybe put your receiver in a balloon and tie wrap it up in the box. Use some sound judgement but as long as it is not standing in water you should be fine. Even if you lost a stock servo because of water damage you didn't lose much and it is going to need replaced water or not sooner than later.
