Weird servo?
lamarw1981
Ok. I got a stock mt and when I turn my wheels to the right using the radio the gas servo turns to. Is it the servo lor the tx and Is there any way to trouble shoot eye promblem?
Don't belive it's the servo but your radiosystem. your servo responds on what your radio tells it to, might wanna reset your radio.
Make sure your servos are hooked up to the receiver correctly. The splitter and the steering servos should be on channel one. The throttle servo should be on channel two.
So, just to confirm, you have the servos hooked up correctly? Are you running any other accessories? Like a kill switch, or the stock failsafe?
Yeah it's hooked up correctly. No kill switch or fail safe. I can try to put a vid on here if u need
is there enough juice on your batterypack? since you say " no kill switch or fail safe" the servo's would act wierd if there isn't enough power on the battery :o
Yeah, try charging the battery. Also, if you could post some pics of the radio box with everything wired up, that would help us figure it out.
Not yet because I am waiting on the rc store in my area to get some. But are the stock servos water proof?
Ok I guess that is the problem because I got it in some water while using it. Ok than r the steering servos water proof then?
