Wet!
Aundre3000
Brunswick GA
Just got done driving my TT my dog was running after it and I forgot it rained hard yesterday and ran it in the ditch!!!!
Ok guys it ran after I did the deed but when I stop it to inspect it the servos was going back and forth bad then they just stop working.
Is it time for some new ones?
The motor ran fine but a little sluggis! :confused:
Deep water halfway the tires!!!
I had the same problem. I make the mistake of doing a great job of hosing my MT off after running it in the dirt for an hour or so. I had been running a X-Can with no extensions. I would get oil all over the entire back half of the truck. So the need to clean it after every run was extreme. My throttle servo would go back and forth like crazy. I would spin the linkage backwards. I unpluged the rec. battery and by the next morning every thing was back to normal. No more high pres. hose for me!
Ok a few guys told me to let it dry out and I did. The bad thing is when i opened the reciever box it had a little water in it. The batt. was wet and the reciever was a lil wet.
I let dry and recharge batt plug back up and nothing happens!!!!! :confused:
Do you all think its the reciever or the servos or all??????? :confused: :(
Pop the cover off the receiver, dry it as best as you can, and let is sit overnight. Most of the time it will work again. Just don't let any water sit in there very long. It will start corroding the circuit board. Electrical cleaner works good too if you don't have compressed air. It will displace the water and evaporate without leaving any residue.
