what alloy arms are theses
steel rose joints
igot the alloy arms installed and attached them to the alloy hubs. but it just don't seem right . the rosejoints seem really tight to the arm and i put 2 washers between the bolt and the swivel on the rose joint. the plastic one i took off had a raised head on the swivel ball and the alloy ones i just installed do not. am i missing a spacer??? or is that how they fit. i added some photoes to my marder photobuckett album have a look:D
http://s766.photobucket.com/albums/xx304/deerjamie/fg marder/
also i require a stering stop for one side see pic of one i have . any ne got one or a link or part# for just the bullett shaped stering stop that mounts to the hub
Can the arms be reversed?
Back-to-front?
Can top be put on bottom, bottom on top?
Just a thought?
dono why i would ? they mount nicely, but wear the arms bolt to the hubs is wear my concern is . on the stock plastic the swivel ball is raised , so when you bolt the arm to the hub there is a gap of about 1/2 cm between the plastic arm and the hub. but with the alloy rose joints they almost touch the hub, again i installed 2 washers to make a gap , and it works but is it right???? see picture #4 on my Photobucket album.
Just located another post with arms /hub issues and followed a link and these are what i need i believe;
are they required?
http://rc-car-online-shop.de/shop/e...4429-02-steel-taper-disk-5mm-bore-4-pcs-.html
