What are you anal about on your rc?
Motakitty
Just curious what are you all anal about on your rc.mine is that the wiring must be clean and I like it when you can't see the head of the zip ties.
Everything. LOL
After I run them, I can't even put them away until they get detailed. :)
Getting my aluminum wheels dirty.Changing wheels to go from the track to the parking lot.I have an xt I will convert to a xb and put road tires on it.
If I was as anal as most I wouldn't be even using them. I have enough time for maybe a tank or 2 on weekends but still can't give up:beer: bash on
my stuff is never spotless on the outside, just wash off with the garden hose then take the air compressor to it, then run it on the bench to dry it off. But, when i assemble engines? all non steel parts are scrubbed brushed under hot soapy water, use 1000 grit silicone carbide sandpaper -dry to the jugs ports-cyclnder junction, then scrub agan under hot soapy water. Crank- bearings- seals are cleaned with solvent, sprayed with methanol, dried, then pour pre-mix on them. put into baggies before assembly. The tools are also inspected for dirt, chrome chips, even the bolts for the engine are scrubbed clean. The airfilters? thats of paramount importance- cleaned in a white bucket until no trace of dirt is seen in the bottom of the bucket- then rinsed off under warm running water in the bath tub.- then oil as usual. yea, just as obessed as you guys- like i say- the cars outward appearance is dirty, but its all about the nuts and bolts.
I don't clean mine as often as I should but every so often I will take em almost completely apart and give a good deep cleaning
solder joints and neat wiring. proper decaled body ..... a pro looking car makes people nervous. always make the rear of my car look the best as thats all people see :p
Doesn't neat wiring make working on the car easier, I always tell my brother to clean up his birds nest:D
I'm more ocd than anal. Things have to be set up a certain way. No sloppy wiring, good tire alignment, no loose or poorly set/tuned parts. I don't mind not cleaning my rides as i stay on top of things a la the aforementioned. I don't have show cars like some here, ahem, Brian. Lol
The thing I don't currently like is the play in the front. Namely the play in the upper front link. I'd rather have an upper a arm. Same w/the rear.
