What are you guys running for light bars
91300zx
I am a LED Wh@r3. The more the better. Wondering what you guys are running for light bars etc. I noticed Integy offers something that bolts right to the cage, anyone have experience with it? I am only rocking the light pods since they came with my kit but I need more lol. (green LED is the killswitch)
I got this Invora 56 LED bar... pretty happy with it.. It sits above the factory light bar and f.bumper now though. Hooked up to a light controller.
20221010_091346-jpg.83864
20221010_091326-jpg.83863
That sure looks nice and bright. What light controller are you using? What are the benefits?
Its the same light controller that came with the light bar. It has two outputs... I have one output hooked up to the front light bars and the second to the rear tail lights. The controller lets me do front solid... or fading in and out... same for taillights all at once or individual... and then there is a strobe feature for rhe q outputs as well.
When i start doing the body I am going to put more lights on it OFCOURSE hah.
I generally look for the "3W" leds
that sounds fun!
There are so many different lighting options online... by any chance has someone figured out the brightest light option you can get (powered by 6-8v rx battery) ???
Only last option I can think of otherwise is the use a 9v battery and wire a relay into the light controller so you can turn them on off from tx.
LEDs are sort of addictive :p
Once my new Flux Baja arrives I was planning on making some high powered lights from the stock spot lights :cool::cool::cool:
are you mostly electric already?? or are you going from a gasser??
Decided to see what I could come up with for starters. Just need to figure out a way to mount it. Might as well put some scrap to use.
i seeeeeeee.... what led strip is in there and what voltage?? looks bright
They are only rated for 5v, probably a cheap amazon set I don't recall, and im sure they will burn out sooner than later. Ill make do until I find something that will work.
