What battery does the FG Leopard run on?
daivik
Billericay, Essex
Hi guys,
Got an FG Leopard from my uncle (hasn't be out of the garage for a GOOD WHILE! And i was wondering how to charge it??
As in i have a universal charger, and the charging cable/pin, i just need to know what power setting to have it on, when I am charging the battery.
Thanks in advance.
Eventually, you should switch to a Li-Po battery. They last much longer between charges. For example on my on-road FG i have a 5000mah 2 cell battery that I charge once for every 10 times i go race.. I know it's a bit of overkill but i like it.
Chris
Chris
Chris,what voltage is the battery?
J.
J.
I'm not sure, but I am charging it on 180mA and that seems to be doing the trick. Could you please (to all) look at my new topic/thread on "Brakes Help" because I would REALLY appreciate the help because I am pretty baffled by it at the moment. Its in the FG Leopard section.
James, I believe it's 7.4but i can't check because it is underneath the velcro that is holding it down. I have a li-po regulator on it and it's letting 6v to the electronics.
Chris
