dunno much about pushing anything to it's limit, except my wife's patience,don't ask, it wasn't pretty. But i know when you do something to any motor that's it's not meant for it, it will eventually break something. Price you have to pay for a short burst of fun. I even read once one guy thinking about running nitro fuel on our gas motor. Good luck. Old adage applies here "if it ain't broke, don't fix it!" and to that I say "Amen" which I just found out actually mean "I agree" I must have said this word a gazillion times and never knew what it meant, till' now, that is. go figureTriggerman77 said:It should run like a Raped ApeI use to run 110+ race gas in my dirt bikes and four wheelers. Keep in mind It will not like regular gas after running it for awhile
I love guys (in a straight, heterosexual kind of way!)BIZCO-RC said:i think im going to try 110 this weekend
I'm assuming these are modified, high compression engines? In that situation, I could see where high octane fuel would be beneficial, but in this case, with these 2 strokes, you would see little to no benefit.Triggerman77 said:D. good theory but It makes a Difference !
I have ran Cam2 and 110+ and Methanol In every thing from Racing carts to Racing ATV's and MX Bikes for 16 years
What this discussion boils down to is this, in my humble opinion, “who’s got more money to burn?” I mean when you cross the line, there will be consequences, and you don’t have to be a rocket scientist to know that, which by the way is and always been a “stupid phrase” but that’s another thread. So when you decide to push the envelope and get out of your comfort zone,2 things will happen, either you will discover a new frontier and discover we can use high octane or crash N’ burn and that’s where the “lot of money to burn” theory come in. hey, if Chuck Yeager didn’t gamble with his life and break the sound barrier and go MACH 1 in 1947? we’d all still be traveling Europe at a snail pace twiddling our thumb along the way. But me personally, am not a “Chuck Yeager” kind of guy and will choose to sit this one out and let the next guy do it. But I’ll be rooting for him though and hopefully if he succeed he’ll share his experience with us then we can all run high octane fuel to a 91% octane motor which was specifically NOTED in your MANUAL!forist said:91 is the lowest recommended for these motors here is what is says for a 29cc from DDM
Chung Yang CY29RC engine, Engine requires 91 octane (using the R+M/2 octane rating method) or higher fuel, mixed 25:1 with 2-cycle oil (5 ounces per gallon).
Your absolutely right Deluge. Octane rating has nothing to do with power. It's a rating on a additive to prevent pre-detonation in engines. Here's a quote straight outta Wiki:Deluge said:Correct me if I'm wrong, but I was under the impression that higher octane fuels are only beneficial in high compression situations. The higher the octane rating, the more detonation resistance the fuel has. It doesn't have any more power than, let's say 89 octane. Also, 89 octane would provide more thermal energy than 100+ octane. So, unless you're running an ultra high compression engine, you won't see any benefit. I'd stick with 91 octane, which is what is recommended.
Now with that being said I believe high octane race fuels do have their benifits which has nothing to do with the octane level. Race fuels are much cleaner than pump gas in the fact that they do not have alot of additives for enviromental protection, detergents for cleaning deposits, etc.Wikipedia said:Octane is a gas 2,2,4-trimethylpentane (iso-octane) and heptane which is used as a reference standard to describe the tendency of Gasoline, Petrol, or Benzin fuels to self ignite during compression prior to the desired position of the piston in the cylinder as appropriate for valve and ignition timing. The problem of premature ignition is referred to as pre-ignition and also as engine knock, which is a sound that is made when the fuel ignites too early in the compression stroke.
