What filters are you all running?
vafan13
Are there any particular filters folks have gone towards? Are people using rednecks and/or outerwear still? This would be for grass and dirt.
I was looking at either the DT1 3-stage, possibly with outerwear, or the TGN Easy Clearance with the corresponding single-stage redneck. Former being decidedly more $$.
I use sort of outerwear to keep grass and bigger things from my foam. I think any filter is fine, as long as it uses foam which you can take out and oil yourself.
so many options for the baja fella (y),
the uni filters work well, the full length and short stack,
the dt1 donkey dong filters are spot on as well :D,
even the stock filter works well, only issue with the stock one is the daft clip that can pop undone sometimes,
just keep em clean and oiled and all will be well,
outer wears are good, i only tend to use em if its really dusty area though,
Well now that you've called it a donkey dong, I might have to get the DT1.
