What fluid in the rear diff?
VooDuuChild
My 5ive came with a leaky seal in the output shaft (I'm assuming) of the rear end. So I have to tear down, re-seal and refill with fluid. What weight should I look into? I saw a fella on youtube that was running like 2000000 or something in the rear and center......said it helped with understeer. I personally like the idea of a car that drifts in the corners and doesn't push the nose.....what advice would you give?
I run 20K front 100K center and 10K rear, but sounds like you want different setup. I wouldn't go thicker than 100K in front or rear diffs....
