Thank Truck, but I ended up going with the hitec 5755 or some thing like that! lol....I was told I can just use one of those for steering, ill let you know how it worksracetruck said:Airtronics has a servo that you can try here's the number 94780 specs 6V torque 423 in. oz. speed 0.15 sec tower hobbie price 117.99or the 805bb for 40.00 that is what i run with plastic gears and it has done fine on the track
I think you might be confusing it with the 5645?racetruck said:the 5755 don't fit the stock steering theyre the same as the throttle servo
You are right the T/B servo is standard sized, the 5755 is a "large scale" servogoldwing1800l said:Racetruck i thought the throttle servo was a standard size servo not the same as the steering hum???
This seems to be brought up quite often. Has anybody made a write-up for installing aftermarket servos on any of these vehicles? I think it would be helpful.yellowjacket45 said:does the 5755 fit the stock location ok or does it need modifying
