PHillary
I have a 23-26cc engine in a Redcat Baja Truggy I have been trying to get started for a friend....the motor turns over fine and gas is getting into the cylinder but the spark seems faint or non existent at times....could it be that the coil wire itself is bad or is not receiving charge to start the motor.....correct me if I am wrong but wouldn't the charge for the ignition come from the battery box somewhere to the ignition coil or does the pull start itself give power to the spark plug on these type of engines? Thanks in advance for any help.
