Small2Large
- Atlanta, Georgia USA
Is it a good Zenoah engine, or a knock off? How big is it?
Thank you
Thank you
They are a clone of the clone CY. The parts are all compatible with the Zenoah and CY.
This is information I recieved from an owner of a Rovan Terminator.
As far as I know they are the same truck.Hi,
Is the Rovan Terminator the same truck as the T1000? I saw this on the net (see link) and it shows the engine in the T1000 as a Fulie.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=300350052205&ssPageName=STRK:MEWAX:IT
i always thought that the engine,s are not a clone of either, as they have a one piece clutch housing cast on the engine case..unlike cy /zen you can remove the clutch housing...or have they changed the set up...
The Rovan is a exact copy of the cy. The clutch housing comes off the block, and all parts are interchangable with the cy/Zenoah.
I can forward you the pdf I recieved from Rovan.
Nope, but I have seen one. If memory serves me it was also a 3 bolt head.clubin ..
no need i take your word on it......
do you remember or know which engine has got the clutch housing cast as one piece with the block???...
mine came with a 29cc engine, not sure of make of it, just know its a fuelie 29cc. very good and strong motor so far for me, no issues with it running, and clutch housing can bolt to engine so its removeable, replaceable.
ok, least mine seems to be a good strong running engine, so far. and the added deep well Vstack i just put on, replacing the shallower Vstack, should make it better. the one i had gave it lots more umph, and this newer one, should do a tad better.
it may be a clone of a clone of a Zen, but at least its working good.
