what oil
FESCUE101
illinois
what is the best available 2 cycle oil? i cant find amsoil where i live and i just bought a new hm baja 30.5 and i want it to last. so what oil is the best but can be found everywhere ? cant wait till my baja gets here!!
Im using the Klotz Techniplate with great success so far. On my 5th tank and I love the smell of it. Just make sure whatever you choose, its synthetic. Proper break in is critical to the longevity of your engine!!!
Maxima Castor 927
Castor 927
Racing 2-Cycle Oil, Pre-Mix Only
Castor 927 is a unique blend of highly refined castor oil, a specially prepared synthetic and an additive system that reduces carbon and gum formation and provides excellent rust & corrosion protection. Castor 927 also contains an exclusive additive that keeps power valves cleaner and working properly. For all of us that wish to keep our air and water cleaner, Castor 927 is biodegradable. Castor 927 keeps on lubricating; where other lubricants turn to carbon or vaporize, and provides extra protection on cylinder walls, bearing journals and other critical areas at temperatures much higher than other lubricants.
Usage
Castor 927 is ideally suited as a premix for both leaded and unleaded fuels.
Recommended Premix Ratios
50-80cc (24-32:1) 125cc (24-40:1)
250cc (24-40:1) 500cc and up (32-60:1)
Technical Data
Color D 1500 Yellow
Gravity °A.P.I. 17.6
Viscosity SUS @ 100°F 617
Viscosity SUS @ 210°F 73
Viscosity cSt @ 40°C 133.1
Viscosity cSt @ 100°C 13.79
Pour Point, °F -5
Flash Point, °F 420
Fire Point, °F 480
Viscosity Index 99
SAE Viscosity 40
