FancyPants
Rob You hooked me up with some great info...from what you told me about the bearings, locktite and making sure everything is fastened down, is there anything else I should do in prep before the break-in process?
Good idea.bob c. said:The wheel nuts like to come loose,and you will watch your wheel run away,(mine did that) so I took a dremel tool and made some notches on the back of the nuts so they would grab better on the wheel hub,worked great..
do you have any pics to show how you made the notches?bob c. said:The wheel nuts like to come loose,and you will watch your wheel run away,(mine did that) so I took a dremel tool and made some notches on the back of the nuts so they would grab better on the wheel hub,worked great..
ahh ok...its all coming together now.RCDAD said:This is what your after.-
It is only because they don't carry the Redcat line. They want your business.I mean to me looking at traxxas comparisons (1/10 models) and Redcat...the redcat looks more durable vs the plastic everything. just wanted to know what you guys thought of this interaction.
