What's the best pipe for speed?
i hear thats a great motor, though was designed around a full mod 27.2 (the OBro 27.2 to be specific). but i hear it runs very well on other full mod motors as well.
may not be the best option for a 27, but shouldnt be a bad pipe by any means.
I still think the JPv2 or V3 pipes have the best overall topend, but the low end is a bit ehh, so don't expect to snap off the line. it ll take of ok, and get better, then the pipe will come on, it ll sound like it downshifted and rockets away.
this is assuming your running a Baja
Yep its a baja...... ok so i'll go with the jetpro pipe then.
And another thing, to go full speed what gears do you recomend?
as tall as the motor can pull.
im running 19/55 on my Yamafied TS 30.5 and 18/56 on my ESP 27.2 though it would pull 19/55 fine. the tallest you can get (with out a 2 speed) is a RC4WD 20/54. If you run the TR HD Clutch, TRs 20t pinion meshes with the RC4WD 54t spur.
if you are running a stock motor. thats some tall gearing. don't expect it to get out of the hole very quick with 20/54, but hang on when you got it going. shits gonna come up QUICK AS HELL>
