whats the broken rear diff case fix!!
hongnor
poole dorset
hi just broke my rear diff on my mcd racerunner .. the pinion end of the case broke , luckily not too much damage to the crown and pinion ... whats the fix ...:2guns:
Replace what is broken? You will have to take some pictures of it - to know which parts to get post them, I can help you out. Do you know what EVO it is?
it for the evo3 comp , only 5 weeks old ... i will add some pics later , but its the front of the rear diff case arround the pinion ..:2guns: ..cheers
Who ever you bought it from should wty. it for you. All you need is a EVO III diff case.
i am getting one for nowt , but they said its not normaly a warrenty issue , but , what i meant was , is there anything that can be done to stiffen up the area , on the new gear case ...
hi mate, i saw you up at carpark in poole about week back, i had my white baja 5t with me at the time. i had same problem with mine and was constantly being told that i was applying to much/two little pressure when tightening the bolts. i went through about 3-4 diffcases , the last one bent the rear centre dog slightly and took a nice chunk out my feul tank. eventually i got a updated case that looks to have more material, but only have one tank on it so far, so cant reli say, tell me when your next goin for rag, il bring mine with and you can see new case.
alright mate .. was going to go out for a bash down nuffield one night , but have got my new servos for the rally car .. and they gotta go back ....
ive got a new diff case , just gotta rebuild it ....
ill be out sunday thou at the track .....send me a pm if your going out ...
