Wheel Rings
Rammer
The blue wheel rings,on the back of RAMPAGE wheels are very loose.One fell off when I unpacked the wheels,be careful not to loose any.
Using some sandpaper,I scratched up the inside of the rings.Then scratched up the inside of the wheels.Where the rings go onto the wheels.
Cleaned all sanding residue off with rubbing alcohol,and let dry...
Epoxyed the rings to the wheels using ( 2 Ton Clear Weld Epoxy ) .....
Epoxy is gasoline and water proof,they will not fall off now !!!!!!
Also make sure you don't get any epoxy inside the wheels,where the wheels mount to the truck ........ :cool:
Hell!! you made sure those things weren't going to fall off again. I just used a little CA glue. So far so good.
Happy Trucking.......
I wanted the wheel rings to stay on for good.Super glue might work too,but it tends to leave a white residue.I use super glue for striped out screws,that go into plastic.....
