jackobyte
Seen this idea off the site somewhere, not sure who done it but it looked like a good idea.
So hence forth i decided to try it out.
Here are the results so far.
Its made up of some 6mm threaded rod and 2 x 6mm steering ball joints with a plastic sleeve over just to tidy it up a bit.
Still need to do the other side (voo is graciously going to donate a couple more ball joints so i can do the other side), then it needs testing to see if it interfers with the rear shock set-up.
The reason for the mod is the back wheels were pulling in alot on acceleration and my drive shaft sometimes hit my gearing. Hopefully this will stop the back wheels from turning in.
