Wheels wobbly and lots of play
nolivy
Brandon Manitoba
hi, can anyone direct me on what to check for this problem, if the baja 5b is on a stand, it is very easy and there is a noticable wiggle of the wheels (front and rear) even if you push a bit with one finger.... thanks.
check the pins are in correctly at either and of the wishbones and that the wheels are seated correctly when you tighten them up
Not sure but you mIght be able to shim them as with the axles(can't remember exact part name) they mount on.
most the time play in the wheels come from worn out rod ends......the metal pivot balls over time reams out the plastic end a lil bit and that is where you get the play, just replace your rod ends and you will be good. I have 4 bajas just incase you are wondering
