Where can I buy shock O-rings ???
leetmodz
I need some o-rings but I cannot find them anywhere on the net.
Anyone have links to any that will fit?? :)
I don't see why they'd be different. What you could do, is take the o-rings to an auto parts store, or a hardware store and see if they can match them. You could probably get a set for all four shocks for cheap.
I'm not sure if the hardware stores o-rings would be compatible with the oils used.
I found some o-rings for the mcd shocks that look the same.
http://www.largescalerc.com/mcdoilfilledshockabsorbershafto-ring.aspx
Does anyone know if mcd shaft thickness is the same as the rampage xb shafts?
Thanks
