where can i get a 33 tooth 4 pin style gear?
No such item that I am aware of. The only 4 pin gears are 25, 29, 31, & 35. For a greater selection you need to use the square drive setup.
The gear ratio chart shows both Rampage gears and MCD gears. Redcat doesn't offer a 33. MCD does, though. But they either plastic or really expensive. You have the 4 pin setup, so you don't have the option to run MCD gears.
