where can i get a bigger engine than a 30.5 r how can i make it faster
thanks man u really helped me...1 more question wat settings do i run my stock xt on 2 get the most speed an power
Until it's broke in you should be 1.5 turns out on the low needle and 1.25 out on the high. This is not for performance. It is on the rich side to keep things lubed and the temp down during break in. Once you have a few tanks through it you can start to lean it out for performance. The stock carbs are ok but not as consistent as a walbro. So I can't give a awnser on a setting. I have a MT and a XB and the settings are different. Just do small amounts at a time with it running so you can hear the differences. Take notes and wright them down it will help you. The low needle normally is a little richer then the high. As you lean out the low needle the motor will start to rev up you can back off on the idle screw to compensate for this. For the high, place you car on a stand and run it full throttle as you lean it out. Once you have leaned it out to the point where it starts to cut out, richen it back out 1/8 a turn. Most of the time you end up around 1 to 1.25 on the low. And between .75 and 1 turns out on the high. If you go too lean you will seize it up. Invest in a laser temp gun. They can be a engine saver and their only about 30 bucks. You want to run around 250deg or cooler. The leaner you run the hotter you run. The unburnt fuel helps to cool. So richer runs cooler. The end goal is to find a happy medium.
Also, check your plug color after you do a few speed runs. This will tell you if you're running too rich, or too lean. You want to aim for a light brown color, almost like a brown paper bag.
Plug Color Chart
