Where to buy new gears
JSoto777
Lovington NM
I ran my chimera sr, and the gears melted!
Missing teeth etc.
I was wondering where to buy some high performance gears that won't wear out so quick.
Thanks
JSoto777 said:
I ran my chimera sr, and the gears melted!Missing teeth etc.
Thanks
1- I can't tell if you have plastic gears or not. If you do, then upgrade to metal gears.
2- I assume you have the plastic gear plate (the culprit). Get an aluminum one. That will save you a lot on having to replace gears over and over again.
3- rampageshop has gears.
The came stock with metal. I think they r brass.
I need some tougher metal
And yea I have plastic gear cover.
Getting the metal will help the gears?
JSoto777 said:
The came stock with metal. I think they r brass. I need some tougher metal
After a kill switch I believe the aluminum gear plate is the next most important upgrade on a any car using plastic gear plate (including the MCD and such). The reason why your gears striped is due to the melting that happened on the gear plate. That melting misaligned the gears causing them to grind each other.
It doesn't take much. Just enough that the gears aren't running true and they will grind/melt. In fact, I've read where some people run the aluminum plate and MCD plastic gears to save some mass in the drivetrain. The plate isn't going to melt and the plastic gears are much lighter and will last quite awhile in conjunction with the new plate.
That not only makes perfect sense but it's also very smart.
