ChuenouXiao
I prefer same size as stock but clear.... any good site?
So this is the same size in diameter as the stock fuel line?RCDAD said:
Nice.... do you like clear fueling?Deluge said:Yes, it is.
Do you think 1 foot which is 12 inch is enough? To replace both top and bottom of my fuel line?Deluge said:I use the transparent yellow fuel line.
How do you take out the line from the fuel tank? I believe the fuel line just goes through the tank right? Just pulled them right out huh?Deluge said:I'd get 10 feet. It's nice to have some laying around, just in case. It's only 80 cents a foot.
The lines will need to be replaced again.I'd get 10 feet. It's nice to have some laying around, just in case. It's only 80 cents a foot.
What's the reason for this? You've got me worried now lol, I just installed those full force brass fittings on my tank and the return fitting goes all the way to the bottom of the tank.Deluge said:Also, when you put the new return line in, it should only go about a half inch through the grommet.
I was just explaining that it doesn't NEED to go to the bottom. It'll work fine either way. I just don't like using more fuel line than necessary.jeffp83 said:What's the reason for this? You've got me worried now lol, I just installed those full force brass fittings on my tank and the return fitting goes all the way to the bottom of the tank.
Where do I get the gormet from? Any sites?RCDAD said:Be carful removing he gromet they tare easy. I always have one ready just in case.The lines will need to be replaced again.![]()
Large Scale RCchuefengxiong said:Where do I get the gormet from? Any sites?
