Well Stiggy,the servos's I'm running wouldnt allow a biro spring to return them,the spring is just too weak to return the arms.
J.
J.
What servo are you running with the biro spring set up stig?? As Voo says I don't think this would with my set up??
Can you operate a kill switch from a 2ch set? Is it Charlie that has this set up where he can switch off the tx to activate it & kill the engine?
J.
There is now a 2ch kill switch made. http://www.rckillswitch.com/products/products/killswitch.php
It will not work on all radios though.
Again jmo.![]()
i ve tried a spring, works usually but they don't do crap when a servo fries out locks inplace. a sring the size of the eifle tower woulnt budge a good quality servo that poop itself and turns ino a mig welder.
only then that will do that is a greased pig wrestline champion and a remote kill switch.
i don't know about you guys, but at 43, im not gonna be able to catch these things at even 1/4 throtle, let alone WOT with a fused servo. lol
Again jmo.![]()
No need to spend any money.
A small spring out of a Biro fixed to throttle lever on carb and attached with a small cable tie to rear bulkhead works perfectly.
Below is from our club website:-
FAIL SAFE SYSTEM
1. Cars should have an electronic and mechanical failsafe device that must return the throttle to neutral when activated. I.e. Through loss of battery power and/or loss of radio signal
Please note:- The electronic failsafe on your handset will only work (If set up) only if your car goes out of range of the handset or loses radio contact with handset for some reason.
If for any reason the receiver loses power (broken battery or battery wire etc.) and the throttle is open, the handset failsafe will not have any effect, but then a mechanical failsafe will work and will therefore stop the car.
Example of a mechanical fail safe on a Topstox. (see Picture)
In the event of a loss of battery power to the receiver, then this spring will return throttle to neutral. The one in the picture is from a ball pen. (Too strong a spring and servo may struggle to open throttle, too weak and it may not return throttle to neutral)
On a Sprintcar or even a straight forward Marder, a spring fixed to throttle lever on carb and attached with a small cable tie to rear bulkhead works perfectly too.
ooh, that must have stung. not good.
I'd put the blame for that one on the RC driver, if you're in public it's your reponsibility not to cause a problem. Even if that means packing up for the day when a kid starts to ride the track.
I fly big (i.e. 7m wingspan) power kites, and often have to stop because a member of the public fails to twig that it's a bad idea to walk under the lines (if it can lift me several meters off the ground, imagine the damage that would be done by a taut line wrapped around someones arm or kneck, and imagine the ensuing court battle / jail term)
Very true Brawn,wise words mate.I never run mine in public nor when theres anyone around.......apart from Jacko....not arsed if I hit him!.
J.![]()
An unpowered servo needs very little pressure to return it to neutral.
therefore a biro spring is perfect. If you have not tried it then you just do not understand how it works.
It is the easiest and cheapest and most reliable method of stopping a runaway in the case of a broken battery or power lead.
