which one 5t or 5b
johnnyblaze
New Member
Iam getting a baja but don't know which one? i will be bashing with it.which has better handling,jumping,ground clearance important because
there are a good amount of rocks where i drive.thanks for the help
I'I
I'I
I would get either the 5T or 5b SS. If like building stuff and you already have the radio and TX go for the SS. Both trucks have the same motor and the SS is significantly upgraded from the standard 5b. By the time your done both trucks will cost you about the same money. There is a new 5b 2.0 RTR but it still has the smaller 23CC motor.
ground clearance is the same between them, they are all the same platform so all can be setup for tall or low gc depending on how you set things up.
If you ever thought you wanted or would want a truck get the 5T. you can go to a buggy much easier and less expensive than you can go to the truck conversion speaking.
the rest of them are basically the same with only minor differances between the SS and the 5T. but the 5B rtr is different yet. maybe get a version 2, which is better than the rtr, but not quite what the SS is.
man if it was me i would get the 5t
its all down to your own prefernce im afraid,you cant rely on somebody elses opinion on what you should buy,in my eyes the 5t is a nicer type of machine(don't like bajas) and looks bigger,as for design,much the same.
best o luck
If its not about money then I would only consider the 5T. There are less upgrades to do to the buggy itself. The electronics except for the steering servo are in need of replacement and I would budget them in right away.:)
