which throttle servo up grade to get??
aussie
hi guys
i want to get rid of the crap standard throttle servo.
so which brand and model servo is good one to get ??
do i get another quality digital servo for speed/responce be good ??
here is a couple of seen, hitec 7955,hitec 5475, hitec 985 or the hs 5645 or hs 5985 ??
apparently the 5625 is a digital high speed and the 5645 is high torque servo.
cheers
glen
Tower hobbies TS 160 digital, metal gear, ball bearings. Made by hitec. Uses hitec gears. 131oz., .14sec, @6v. $44.99. Im still loving mine. It has enough power to lock up all 4 excavators. And fast throttle response. Basically the same as hitec 5625 but $5 cheaper. There might be a tower labeled 5645 if you look.
hi guys
cool,thanks once again for your kind help and advice
i will get the 5645 then.
much appreciated fellas
cheers
glen
