G
Guest
Guest
Thanks.
I'll show them around for ya.
It'll rip, dude. I love mine. And nobody knows what the actual HP output of the stock engine is.Guantanamo Joe said:Does that kit give a better top end? I am looking to make my Dunerunner kick assWhat kind of HP do the stock engines have vs what this can give? I keep seeing engines that give 4.5 or more HP, but I don't know what we are starting with for comparrison.
It's an HY. Which is basically a CY clone. So, most of the parts are interchangeable.Guantanamo Joe said:Also, what is the actual name of our 30.5 cc CY engine? It would make looking for upgrades easier if I knew which ones fit and don't...
Anytime you add anything to the stinger of the pipe, it'll hinder performance a little. Doubt it'll be noticeable, though.Guantanamo Joe said:I thought about getting a silencer for the pipe, but don't know much about them... do they work well? Do they hinder performance?
Use plenty of Loctite.Guantanamo Joe said:and what the hell would I do to mount a silencer to the dominator side pipe? Even with RC DAD's long silicone heat tubing, it would make this thing look like some alien craft... ha ah haI almost bought one of the rear dominators from dave's blemish sale for the dunerunner, but I like how small the XCan isI am thinking though about something to get the exhaust tips out past the rear wing because I am tired of the oil all over the wing and rear braces...
This kit comes with a gasket? Is the 1 yoy recommend better or thinner? Im considering this kit myself.Deluge said:Those kits don't have the clearance for a +2mm crank. You'll need to stack cylinder gaskets if you want to run those. Which isn't recommended.If you want to stick with a stock engine, this will work...
ESP Modified GP290 36mm kit
Or for a few bucks more, you could get a Champ port. This is a beastly kit. I love mine.
ESP Mod/ESP CHAMPIONSHIP PORTED GP290 36mm kit
If you go with the Champ port, don't order it with the crank. The stock engine comes with a +2mm crank, so you don't need it.
Also, I'd recommend this cylinder gasket with either of those ESP kits...
Zenoah RC Cylinder Gasket
Now we're talk'n!cherryride said:how about leather interior for my Woodster Joe?hahaha
Yea I stocked up on them with last order.Guantanamo Joe said:http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.4153/.fI ordered a couple of these as well
