white lightning easy lube
alfred e numan
went to wal-mart in pendleton this morning and found this bicycle chain lube. it says its a wax-film, self-cleaning lube. i applied this to the ball joints-shock, sway bar-ect. i think this lube may not be a good idea on the tranny gears- too thin. i smeared some on the a-arms, diff housing- shure is slick, we will see how it sheds. i wonder- if i wiped this on the inside of the rims- we all know how these collect dirt-mud. Any one out there ever put dirt-bike skidpan foam in there chassis- fill up the open areas so less weight gets in there-mud runs ya know. uni filter sells this and three types of air filter foam in bulk, i e-mailed uni and asked what is a glue to build air filters with- fellow said a product called plio-bond. - he did not say if this is what uni uses - but it shure looks like the same glue to my tired eyes--
white lightning is decent but definitely not for the gears thell spin the lube off right away....as for ball joints and such should be fine its just not a great high speed lubricant...i used to spin it off the chain of my gokarts and gopeds all the time
