K
Keith81
Guest
can these work ? do you use fronts or rears all around? I think I seen a post where Rob was using these on his old truggy....
How do you shorten them?nz420 said:There pretty close to a straight fit,baja fronts will go on the back of the ramp but need to be shortened(easy to do)to go on the front of the ramp,the only other issue might be clearance at the lower suspension arm but I know you can get an extended bottom balljoint(?) that is used on baja rpm arms.![]()
Funny how you just find things that work. When I'm working I'm always thinking about different bits of metal or plastic parts that could always be handy or modded to fit on my cars.Deluge said:I used pen tubes for my DarkSoul shafts. Whatever works.
