Who make HY motor
Discussion in 'Large Scale RC Engines and Exhaust' started by Rodney Fernandez, Dec 27, 2017.
  1. Rodney Fernandez
    Dec 22, 2016
    5
    0
    Hi all I got a motor but don't know who makes or what car it came from this is what I could find on the motor
  2. Whoduh
    Whoduh Well-Known Member
    Mar 25, 2014
    251
    53
    Fairfax, VA
    Himoto Racing engine.
    Don't know what it came from though.
  3. Rodney Fernandez
    Dec 22, 2016
    5
    0
    Do you know the size of the tag
  4. Whoduh
    Mar 25, 2014
    251
    53
    Fairfax, VA
  5. Phill2
    Phill2 Well-Known Member
    Apr 29, 2015
    180
    10
    Yeppoon QLD Aus
    HY will fit just about anything
  6. sdiz86
    sdiz86 Member
    Dec 27, 2012
    23
    0
    I think it's an CY engine just used by Himotoracing.
    The most known rc engine makers as far as I know are Zenoah and CY.
    And then you have the RCMK and SCZ engines, but who makes them that I don't know.
    And also as far as I know most rc car manufacturers use CY engines in their RTR cars.
    Sent fra min SM-G955F via Tapatalk
  7. Phill2
    Apr 29, 2015
    180
    10
    Yeppoon QLD Aus
    CY and HY are the same animal
  8. kevnick420
    kevnick420 New Member
    Jan 9, 2018
    4
    0
    Cy and hy may look like the same animal but are both very different just as Cy and zen look the same but very different. I have a Cy and hy on my bench and have tried to drop an hy in place of a Cy and they are dimensionaly about 2 to 3mm different in width and motors mounts do not line up
  9. Phill2
    Apr 29, 2015
    180
    10
    Yeppoon QLD Aus
    Have you changed the fan cover like you have to with a Zen
    I'v found HY and CY parts interchangeable.
    Either way they don't compare to Zen quality wise.
  10. kevnick420
    Jan 9, 2018
    4
    0
    Yes I tried swapping covers in between the block itself is thicker from what I can see but will measure to be sure
  11. Phill2
    Apr 29, 2015
    180
    10
    Yeppoon QLD Aus
    Very strange
    Maybe they're different models?
  12. kevnick420
    Jan 9, 2018
    4
    0
    No same 2 bolt zen clone just like Cy but just as Cy is slightly different dimensions than zen hy is slightly different than both
  13. Phill2
    Apr 29, 2015
    180
    10
    Yeppoon QLD Aus
    I put an HY cover on my Zen 290 and it went straight in?
  14. kevnick420
    Jan 9, 2018
    4
    0
    not sure whats up but i am able to swap all three covers between engines it just seems the actual casting of the block is thicker. im no small chinese engine expert by any means i deal with full scale engines but i will eventualy get around to measuring up all 3 units
