atom3624
I've got a potentially very shiny - loads of solid, heavy alloy - FG MT.
I decided it was time for a little clean - reading all of the racer's threads of stripping down, and cleaning, oiling, rebuilding, etc., ......
This was after the recent 'engine / carburettor problems' - bolts used were too long .... another story but resolved now!! How it ever worked is a mystery ... !! It should be great now!
I've the Evo04 long alloy shocks, with the alloy rod ends - this means the inserts top and bottom which wear ....
I've had to replace ALL of these, after perhaps 8-10 hours of 'casual bashing' since the last time.
Seals are OK, so I've simply replaced the oil with fresh as there're no leaks.
The lower alloy support which as the headless screw/grub for the lower end was worn loose, so that's braced with Nylok nuts for now.
The right hand side bracing M4 bolt - previously A2 stainless - had snapped!! Fortunately removal was easy.
Whilst all was in pieces, knowing I'd had quite a decent 'splashing time' I've also replaced all 8 wheel bearings - rubber sealed as it's 'off-road'.
Interesting exercise, but proves that these are fairly high maintenance.
