G-fresh
I was goin tru my second tank from the braking but the car was bogin out if I sto giving gas will shut down now don't star help please
Did you put a fitting on it? Or did you just drill a hole in the cap? You want to run the bulb piece that seals the cap. The other piece you can leave off.G-fresh said:Ok I make the hole should I put back those two rubber pieces back into the cap or not
You don't want to use the choke when the engine is warm, you'll flood it. Only use the choke for cold starts. If you let it idle for more than a couple of seconds, you'll foul the plug.G-fresh said:Hey was up the truck was fine in to like 45 minute then star doin the same poop if I stop stay idle for like two minutes then shut down then don't wanne star I have to close the choke pull like tree time then open choke again and star again but run like is to much gas I play aroun with the low needle but same poop help
