Will I need to change my clutch housing?
almighty15
Using my engine from my Baja and wondering if it will bolt straight in or if I'll need to change any mounting parts?
redcats don't use the mounting post under the Baja clutch housing,, double check for height of post to make sure will fit without putting in a bolt from the bottom,,
You'll need to change the clutch housing from the baja as the baja ones aren't as deep as the redcat ones. I'm not 100% sure but I think the redcats use the same housing as the losi but don't hold me to that.
