Will not start!!!!!!!!!!
Yessabub
ive tried everything and no matter what my rc will not start ive taken the glow plug out and it glows so its not that i also have primed it by putting my finger over the exhaust while pulling. what should i try?
You might have flooded it. Pull the glow plug out and cycle the engine a few times with a paper towel over the plug hole. You can try to open up the idle a bit, as well.
What are u trying to start?gas or nitro engine?because u said glow plug and ur priming with the exhaust.if its nitro ur needle settings are not 1 1/2 more like3-3 1/2
Redcat's site says the LSN should be 2 1/2 turns out. Don't see anything on the HSN. I'd set it to 3 turns out and adjust from there. There should be a 1-1.5mm throttle opening for idle.
