Will these Steel gears fit my 2 speed?
Not sure they would work. If you are standard on the FGMT then you can go two ways.
One is to buy a set without a carrier.
Second is to buy one with the carrier.
I take it your 1st gear (Small) is metal already right?
And yes I personnaly have never run with plastic gears.
All the gears are plastic!
Don't think its had much use as yet, the guy i bought it from fitted them, so who knows, but they look perfect!
Very tempted just to get rid of the whole 2 speed & go single!
What would i need to convert back to single?
Is it better to have single just for a basher?
Cheers
Think i want to replace the 2 pinion gears to metal for now.
I've heard that the first, inner (18) tooth needs to be a special 2 speed pinion gear, but the outer smaller (16) can be any normal pinion.
Is this the case? & anyone have or know where to get them in the UK?
