Will this fit redcats
Yes rcdad sells that one. If this different ratio does not fit does anyone know when differant ratios will ne available
rev9fan1 said:
why would you buy that if this one is cheaper and fits for sure? http://www.rcpitstop.net/belt-drive.html
That one will not fit. It is made for the Carbon Fighter. Those kits are made by the same manufacture as the kit I carry. I am pushing for the other ratios for the Redcats. They tell me it's in the works along with the carbon fiber cover.
rampagemt said:
Ok should be sweet don't get me wrong the 1:1rips ass tho
It is great for the buggies and the trucks running Baja wheels. It's a bit tall for the huge MT wheels on the stock engine.
I am pushing for a lower ratio more suited for the MT tires and a taller ratio more suited for on road and top speed freaks like myself.
na because you gotta keep adjusting them as they wear down, this design is alot better it holds up longer. Thats why if you ever watch NHRA drag racing the blowers/superchargers use this belt design its more stable and it wont slip. V-belts slip like hell!
BIG KAHUNA said:
What kinds of tires fit redcats??
Just redcat unless you get hpi hex adapters then you got a whole lot of options. Many members run hpi wheels and tires.
