nice packing!, i do a similar "blow off" ...just enough water/dilute
simple green to get things moving , definitely easy spray(if not just avoid) on the Rx box/servo outdrives/carb. i use a tight small blowtip on the compressor. add some tilt so run off runs away. submersion /pooling around servo IS NOT WHAT YOU WANT! most hitecs are water resistant , thats NO pressure water contact. i like running it while washing/blowout. ...couple of repeats, then a water displacement solvent to finish to the it while running , like WD40 , Boshield, most dry silicones etc.. blow off excess. always take off wheels( power spray) makes it easy, quick and effective.
