Trebor
not sure of the voltage to wire me tug
i have just bought 2 new lucas 6volt 4ah batteries
problem i have, do i wire them in series to give me 12volts and 4ah
or do i wire them in parallel to give me the same 6volts but 8ah
looking at the receiver it has no battery wire so must be im thinking BEC
its running a 4volt to 15volt motor
and has an electric smoke unit fitted but i don't know the voltage of that
i have just tried the prop on one battery to see i had the wires the right way round
and when i switched off the TX before the RX the motor started to spin fast
is that normal.......i know i should switch off the RX first then the TX
K....
K....
