Sparks1314
New Member
- Reaction score
- 2
I got a brand new red cat 1/5 scale I did everything by the book and I can't get it to start
The black cap is a rubber gromet. You can slowly remove it with a flat head screw driver. They don't screw out. Here is the clear fuel line in different colors http://www.davesmotors.com/clear-fuel-line-by-the-foot-.html i also suggest you get this http://www.davesmotors.com/Brass-Fi...tible-with-Snappy-RC-Kit-5B004X-Fittings.html since the fuel lines are thicker than stock. Hope this helps.I would like to switch to tygon clear fuel lines to ensure you see the flow of fuel, with the black stock hoses these come with you cant see the fuel......still trting to figure out how to unscrew the black cap on the fuel tank where the fuel lines run through to change them out and possibky get a bigger fuel filter
Does the brass fitting need to be cut down?The black cap is a rubber gromet. You can slowly remove it with a flat head screw driver. They don't screw out. Here is the clear fuel line in different colors http://www.davesmotors.com/clear-fuel-line-by-the-foot-.html i also suggest you get this http://www.davesmotors.com/Brass-Fi...tible-with-Snappy-RC-Kit-5B004X-Fittings.html since the fuel lines are thicker than stock. Hope this helps.
No they don't.Does the brass fitting need to be cut down?
