alfred e numan
- Reaction score
- 0
Its cool to see a few members porting there own jugs.- someone had mentioned bout engine bog after there mods. Yes, it could be a exhaust issue- who knows? Heres a cheap WT-990 mod. Its the pressure spring under the fuel bulb-gasket- AKA pop off valve.- This pressure spring has 2 functions- pressure release and reseat pressure.- I can explain further if you ask. The pop off pressure on the stock 990s i have tested is about 32 psi. this is quite high. The reseat pressure is bout 28 psi. IF-IF your 990s fuel bulb is 1/2 full to 3/4 full while ideling- after shut off. Heres the .50 cent mod. go to ddm site, enter this number on his new search engine-- 98-344. This spring will change the pop off pressure lower- the carb will enter fuel enrichment sooner- This springs pop off pressure is approx 24 psi. Its re-seat pressure is 17 psi. This is not gonna hurt your engine folks, it will just make feed more fuel sooner. I must stress this to you, do not pull springs off old weed eaters-chain saws- leaf blowers or start cutting or streching springs, it aint worth the risk- yea, spend a extra .50 cents on your next ddm order- give it a try!! agan- ddm has new search engine- just enter 98-344. Thought i would toss this out to you before i hit the hay tonight.- A.E.Numan.
