MonsterAir
Lone Racer 🤠
- Long Island NY
I'm looking to trade my F1 for a 4wd Sportsline. I'd also be open to selling it.
The car is in good running condition but shows some wear. I had broken the nose on body but patched it up nicely with some spackle tape and shoe goo, very functional and fits perfect. The under side of chassis also shows some wear but that's to be expected I think. Talking F1 w/ 5mm of ground clearance here so why not save buying used rather than getting errked when you scratch up a new one.
I'm selling because everyone here that runs them went 4wd and I can't keep up with them when they run 2wd so I need to move on from it. I have a few videos of it running but no YouTube account so at the moment I can only text or email videos. It starts up from cold first or second pull! I have a video of that too.
Doesn't come with the Savox pictured. It will have a Hi-Tech HS-805BB steering servo. I also replaced the gas tank within the past month.
Needs-
Tires (comes w/ tires but they have almost zero traction left)
Belts (Has working belts just that they seem to be cracking a little bit from age. Probably another season left on them but they will need replacing)
Transmitter/Receiver
Upgrade List -
G260RC Motor
JR Throttle/Brake Servo
Front Disc Brakes
Aluminum Sway Bars
Killer RC Engine Kill Switch w/ Buzzer (I have recently removed this but something can be worked out if you need one)
Track Transponder Clip
I also have some hard to find alignment tools that were rather expensive. Alloy plates that are fitted to wheels with toe and camber gauge. I think all that was over $200
Needs-
Upgrade List -
G260RC Motor
Front Disc Brakes
Aluminum Sway Bars
