x-can question
never mind guys I found out they're not worth it. So I matched the exaust spacer and flang on the pipe to my race ported head. There was a good bit of restriction due to square holes in both the pipe flange and aluminum spacer. It should flow free now. I will make another vid soon. I am changing clutch springs from the ddm 7500 to the hpi 8000 and because cost was low I am trying the mcd 27/33 gears. I will run them 33/27 and 27/33 just want to see how they do on flat ground.
the 8000 rpm clutch springs don't do much for it but make it more of a hand full on take off i would stick with the 7500 springs i think they would even be better with 7000 rpm take offs a lot easier on hardware anyways
