X can
It'll fit. You'll probably want to run some longer stingers, though. Otherwise you'll have a mess back there. Some aluminum tape underneath the bed area will help keep the body from warping.
They have their upsides and down sides in their stock setup. They create a mess and warp the body if you don't put the longer stingers on. You can also try different upgrades and mods to attach to the x can to add some flare to your truck as well. They are not a bad exhaust, they provide low in grunt to engine. However, as stated you will need to add the longer stingers if you don't want your body warping or a mess underneath.
