XB Build #2
Stygian
Banned
Tucson, AZ
Ok, my wife decided she wanted a XB too so I have decided to give her the one I already have and just build me a new one so here are the parts I am thinking about using. If anyone has any suggestions on something different I should go with or if I have chosen too much aluminum please let me know, also if I have forgotten some parts please do share, thanks in advance for all suggestions and responses.
Ok, here's the list
Carb and Motor
Walbro WT-257 Carb.
RCMK Full Mod CR300 30.5cc
7075rc Parts
22mm x 6mm Ball Bearings x4
Front Bearing Holders
Rear Bearing Holders
C-Hubs
Front and Rear diff. housing
Chassis (Raw Aluminum)
Shock Tower Front & Rear
Lay Shaft Mount (not sure if these are really needed so advice would be helpful)
MISC.
TGN Aluminum Wing
Jetpro Rear Mount Pipe
Hitech HS-645MG Throttle Servo
ADA RC Manifold
Snappy RC Ultimate fuel line kit
Fuel Lines
DDM Tall Velocity Stack
RC Screwz
Proline Bow-Tie Front on Desperado Wheels
Boca Bearings Green Sealed (for off roading)
Grafil XB-G Body
Multi Ratio Belt Drive Kit
Killer bee super bee kill switch
Redcat Racing parts
050020
710001
710002
710003
710008
710009
710012
710018
710019
710022
RCDAD said:
That would be an impressive build.
Yeah, thanks to you guys, I have gotten good advice and ideas. I am sure I am missing some odds n ends parts like the axels and and rear axel mounts but I am not sure if I want to go with the stock redcat ones or find some good aftermarket ones and I just hope I'm not using too much aluminum.
That looks like a fun build. I wish I would have built one from scratch instead of buying complete and modding everything. Building one and working on them is most of the fun for me.
I totally agree one if the reasons I'm doing this build
Sent from my HTC One using Tapatalk 2
Stygian said:
Im digging phatcats front/rear shock towers, I just might have to get those instead.
With the rear shock tower it will only work with side mounted pipes or stock pipe
i have the front and rear phatcat shocktowers on mine with a jetpro rear mount pipe. you have to do some modifying to the rear tower. i sent him some pics on what i did must be to hard to redo them to fit. but i do like them alot thanks phatcat.
It's not hard to redo them it's just with that pipe you do not have much room to adjust the shocks.
Would be worth the time to maybe do two types one for the rear mounted pipes and the. The ones you already have
